  • 相同的相机参数,在循环拍摄的模式下,为何每次得到的图像都不相同?
    • import sensor, image, time,pyb
      from pyb import Pin
      sensor.set_framesize(sensor.SVGA)   # Set frame size to QVGA (320x240)
      sensor.set_auto_exposure(True)
      #sensor.set_auto_gain(False,gain_db=128)
      p_out = Pin('P7', Pin.OUT_PP)#设置p_out为输出引脚
      count = 0
          p_out.high()#设置p_out引脚为高
          time_start=pyb.millis()
          duration=pyb.elapsed_millis(time_start)
          p_out.low()#设置p_out引脚为低
          print(sensor.get_exposure_us())
          print(duration)
          print(sensor.get_gain_db())
          time.sleep(1)
          count = count + 1
          img.save("test"+str(count)+".jpg")
          print(count)
          if(count == 10):
              break
      相机参数:
      109740(曝光时间)
      20
      23.8066 (增益)
      1
      109740
      27
      23.8066
      2
      109740
      27
      23.8066
      3
      109740
      27
      23.8066
      4
      109740
      26
      23.8066
      5
      109740
      26
      23.8066
      6
      109740
      27
      23.8066
      7
      109740
      26
      23.8066
      8
      109740
      27
      23.8066
      9
      109740
      27
      23.8066
      10
    • 没看懂什么意思?是指亮度不同?
