识别最近距离的小球
一堆球中别最近距离的球,返回该球距离值,while之后出错,语法错误。不懂find_max(blobs)用法及含义,代码如下:
Measure the distance
This example shows off how to measure the distance through the size in imgage
This example in particular looks for yellow pingpong ball.
yellow_threshold = (39, 99, -61, 1, -80, -5)
clock = time.clock() # Tracks FPS.K=5000#the value should be measured
img = sensor.snapshot() # Take a picture and return the image.blobs = img.find_blobs([yellow_threshold])
for b in blobs:
if b[2]*b[3] > max_size:
Lm = (b[2]+b[3])/2
length = K/Lm
print(length)
附:像find_max(blobs)这种函数是在哪里找和学习能?
在图像中,没有最近的球,只有最大的色块, find_max(很多色块)会返回最大的色块。
