  • 报错:Out of fast Frame Buffer Stack Memory! 要怎么办?
    • 想用VGA格式,但是显示内存不够,报错:Out of fast Frame Buffer Stack Memory! Please reduce the resolution of the image you are running this algorithm on to bypass this issue!,要怎么处理??最终的目的是想用VGA格式(30万像素)去进行二维码识别,要怎么办??
    • 换OpenMV4 H7 Plus,它有额外的ram芯片。
