  • 如何对openmv颜色识别捕捉的色块进行模板匹配?
      thresholds = (57, 92, -65, -26, -4, 45)
          for blob in img.find_blobs([thresholds], pixels_threshold=200, area_threshold=200, merge=True):
              r1 = img.find_template(template1, 0.70, step=4, search=SEARCH_EX, roi = blob.rect())
              if r1:
                  img.draw_rectangle(r1)
              r2 = img.find_template(template2, 0.70, step=4, search=SEARCH_EX, roi = blob.rect())
              if r2:
                  img.draw_rectangle(r2)
              r3= img.find_template(template3, 0.70, step=4, search=SEARCH_EX, roi = blob.rect())
              if r3:
                  img.draw_rectangle(r3)
      请问要怎么改才能实现
    • find_blob可以返回坐标和区域,模板匹配用roi参数限制模板匹配的范围。
    • 我改了一下程序结果报错 OSError: Image format is not supported!
      是怎么回事
      reset=0
          if reset==1:
              reset=0
          blobs = img.find_blobs( [thresholds], pixels_threshold=200, area_threshold=200, merge=True)
              print(blobs)
                  if r1:
                  if r2:
                  if r3:
                  reset=1
    • blobs = img.find_blobs( [thresholds], pixels_threshold=200, area_threshold=200, merge=True)
      这一句,img是rgb565格式的彩图。
              print(blobs)
      这里,你虽然设置了Gragscale灰度图,但是你没有把图像赋值给img,即应该为:
              print(blobs)
              img = sensor.set_pixformat(sensor.GRAYSCALE) #注意这一句
    • 我改了一下结果报错AttributeError: 'bool' object has no attribute 'find_template'
