  • mjpeg_streamer.py运行不成功
    • 显示Type "help()" for more information.
      Trying to connect... (may take a while)...
      File "", line 22, in
      Exception: IDE interrupt
      MicroPython: v1.18-omv-r13 OpenMV: v4.3.2 HAL: v1.9.0 BOARD: OPENMV4-STM32H743
      然后就阻塞没有反应了。相应代码如下:
      # MJPEG Streaming
      # This example shows off how to do MJPEG streaming to a FIREFOX webrowser
      # Chrome, Firefox and MJpegViewer App on Android have been tested.
      # Connect to the IP address/port printed out from ifconfig to view the stream.
      SSID ='xyzbalabala'     # Network SSID
      KEY  ='12345678'     # Network key
      HOST =''     # Use first available interface
      PORT = 8080  # Arbitrary non-privileged port
      # Reset sensor
      # Init wlan module and connect to network
      print("Trying to connect... (may take a while)...")
      wlan = network.WINC()
      # We should have a valid IP now via DHCP
      print(wlan.ifconfig())
      # Create server socket
      # Bind and listen
      s.bind([HOST, PORT])
      s.listen(5)
      # Set server socket to blocking
      s.setblocking(True)
      def start_streaming(s):
          client, addr = s.accept()
          client.settimeout(2.0)
          # Read request from client
          data = client.recv(1024)
          # Send multipart header
                      "Server: OpenMV\r\n" \
                      "Pragma: no-cache\r\n\r\n")
          # FPS clock
          # Start streaming images
              frame = sensor.snapshot()
              header = "\r\n--openmv\r\n" \
              client.send(header)
              client.send(cframe)
              start_streaming(s)
          except OSError as e:
              print("socket error: ", e)
              #sys.print_exception(e
    • 我把print(wlan.ifconfig())注释掉了后,程序能运行到print ('Waiting for connections..') 串口打印出了信息,然后又block了
    • 看上去没连接上路由器的WiFi。确认密码对,和加密方式是WPA_PSK。
