  • 在分辨不同人脸是 提示OSError: Could not find the file
    • Face recognition with LBP descriptors.
      See Timo Ahonen's "Face Recognition with Local Binary Patterns".
      Before running the example:
      1) Download the AT&T faces database http://www.cl.cam.ac.uk/Research/DTG/attarchive/pub/data/att_faces.zip
      2) Exract and copy the orl_faces directory to the SD card root.
      #SUB = "s1"
      NUM_SUBJECTS = 6 #图像库中不同人数,一共6人
      拍摄当前人脸。
      #d0为当前人脸的lbp特征
      img = None
      pmin = 999999
      num=0
      def min(pmin, a, s):
      global num
      if a<pmin:
      pmin=a
      num=s
      return pmin
      dist = 0
      #d1为第s文件夹中的第i张图片的lbp特征
      print(pmin)
      print(num) # num为当前最匹配的人的编号。
    • 因为你没有采集足够的图片,看视频步骤操作。
      https://singtown.com/learn/50033/
