串口数字显示出错
# Blob Detection and uart transport import sensor, image, time from pyb import UART import json # For color tracking to work really well you should ideally be in a very, very, # very, controlled enviroment where the lighting is constant... yellow_threshold = (65, 100, -10, 6, 24, 51) # You may need to tweak the above settings for tracking green things... # Select an area in the Framebuffer to copy the color settings. sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. clock = time.clock() # Tracks FPS. uart = UART(3, 115200) def find_max(blobs): max_size=0 for blob in blobs: if blob.pixels() > max_size: max_blob=blob max_size = blob.pixels() return max_blob while(True): img = sensor.snapshot() # Take a picture and return the image. blobs = img.find_blobs([yellow_threshold]) if blobs: max_blob=find_max(blobs) print('sum :', len(blobs)) img.draw_rectangle(max_blob.rect()) img.draw_cross(max_blob.cx(), max_blob.cy()) output_str="[%d,%d]" % (max_blob.cx(),max_blob.cy()) #方式1 #output_str=json.dumps([max_blob.cx(),max_blob.cy()]) #方式2 print('you send:',output_str) #uart.write(output_str+'\r\n') uart.writechar(max_blob.cx()) #发送数字 uart.writechar(max_blob.cy()) else: print('not found!')
检查了一下没有什么错误,波特率也是对的。而且传递字符的 .write可以正常传递,可以.writethar就传递不了数字,显示乱码,这是什么问题 求大神指教
writechar 发送的是ascii的二进制,比如writechar(65)或者writechar(0x41),发送的就是'A',
既然你用ascii显示,那么,就应该用write('123')或者write(str(123)),这样就发送了'123'这个字符串。
