  • 为什么我openmv控制舵机不能动,请问这个是什么问题,还有就是我这个程序要怎么控制离物体很近的时候稳定刹车而不是倒退
    • Blob Detection Example
      This example shows off how to use the find_blobs function to find color
      blobs in the image. This example in particular looks for dark green objects.
      import car
      from pyb import Servo
      sensor.skip_frames(10)
      sensor.set_auto_gain(False)
      sensor.set_auto_exposure(False,2000)#这里设置曝光时间
      #sensor.skip_frames(time = 2000)
      s3 = Servo(3) # servo on position 1 (P9)
      red_threshold = (17, 50, -40, 110, 34, 127)
      size_threshold = 2500
      x_pid = PID(p=3, i=1, imax=100)
      h_pid = PID(p=0.03, i=0.1, imax=50)
      s3.angle(90) # move to 90 degrees
          print("x error: ", x_error)
          for b in blobs:
          print("h_output",h_output)
          car.run(-h_output-x_output-50,-h_output+x_output-50)
          s3.angle(-90) # move to -90 degrees
          car.run(500,-500)
    • 请每个问题,单独提问
      比如第一个舵机的问题,请单独开一个帖子,把代码,连线,步骤,清楚的表达出来
