插上数据线和拔下数据线后的程序运行结果不一样?
 总述:正常弹出u盘。程序是识别Apriltag并有两个电机控制漂浮着的装置向Apriltag的方向移动。
问题描述:连上数据线时程序运行结果正确,当视野中不存在Apriltag时电机按照程序正常停止转动。但烧录程序并拔出数据线,重新上电后,openmv识别出Apriltag后电机转动,当视野中没有Apriltag时电机却不会停止转动。
补充:换过电机控制模块和电池,不是这两个元器件的问题。之前拔下数据线程序是能正常跑的,某一次开始突然出bug了。由于插上数据线时程序正常运行,所以应该也不是程序问题,实在不知道是哪里出错了。线路是按照追小球的小车那个教程接的。
元器件:openmv4H7PLUS、TB6612电机驱动、3.7V锂电池、615空心杯电机、IDE版本2.9.0
附程序:
mecar模块:from pyb import Pin, Timer inverse_left=False inverse_front=False ain1 = Pin('P0', Pin.OUT_PP) ain2 = Pin('P1', Pin.OUT_PP) bin1 = Pin('P2', Pin.OUT_PP) bin2 = Pin('P3', Pin.OUT_PP) ain1.low() ain2.low() bin1.low() bin2.low() pwma = Pin('P7') pwmb = Pin('P8') tim = Timer(4, freq=1000) ch1 = tim.channel(1, Timer.PWM, pin=pwma) ch2 = tim.channel(2, Timer.PWM, pin=pwmb) ch1.pulse_width_percent(0) ch2.pulse_width_percent(0) def run(left_speed, front_speed): if inverse_left==True: left_speed=(-left_speed) if inverse_front==True: front_speed=(-front_speed) if left_speed < 0: ain1.low() ain2.high() elif left_speed > 0: ain1.high() ain2.low() else: ain1.low() ain2.low() ch1.pulse_width_percent(20) if front_speed < 0: bin1.low() bin2.high() elif front_speed > 0: bin1.high() bin2.low() else: bin1.low() bin2.low() ch2.pulse_width_percent(20)
main模块:
import sensor, image, time import mecar sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(10) sensor.set_auto_whitebal(False) clock = time.clock() size_threshold = 2000 def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() img = sensor.snapshot() blobs = img.find_apriltags() if blobs: max_blob = find_max(blobs) x_error = max_blob[6]-80 y_error = max_blob[7]-60 print("x error: ", x_error) print("y error: ", y_error) img.draw_rectangle(max_blob[0:4]) img.draw_cross(int(max_blob[6]), int(max_blob[7])) mecar.run(x_error,y_error) time.sleep_ms(500) else: mecar.run(0,0)
可能是你保存的步骤不对。先脱机运行闪灯测试:https://book.openmv.cc/example/02-Board-Control/led-control.html
然后写一个程序,当找到apriltag就亮灯,找不到就灭灯的程序,脱机测试。
