  • 串口通信有问题,openmv端能正确输出,可以32出错
      import json,pyb
      from pyb import UART,LED
      green_threshold  = (0, 58, -49, -19, 39, -17)
      red_thresholds  = (0, 100, 7, 127, -128, 127)
      led3=pyb.LED(3)
      uart = UART(3,115200)
      uart.init(115200,bits = 8,parity = None,stop = 1)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
      colors = [
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
      U1=1
          while(U1):
                  if (i == 0): continue
                  if (len(detection_list) == 0): continue
                  for d in detection_list:
                      [x, y, w, h] = d.rect()
                      #zuo[0]=math.floor(x + (w / 2))
                      #zuo[1]=math.floor(y + (h / 2))
                      print(labels[i])
                      uart.write(labels[i])
                      led3.on()
                      u1=0
      上面是openmv的函数,下面是32
      void Openmv_Receive_Data(int16_t data)
      //	static u8 state = 0;
      	openmv2=data;  //定义一个变量接收openmv发送的数据
      OLED_ShowNum(70,20,openmv2,3,12);
      openmv的串行终端上可以正确打印,但是32上不行
    • 我运行代码没有复现出你的图片里的错误。
