  • 为什么一传输数据就会出错呀?
    • from machine import I2C
      from vl53l1x import VL53L1X
      import time,pyb,sensor,json
      uart = UART(3, 9600)
      i2c = I2C(2)
      distance = VL53L1X(i2c)
      led1 = pyb.LED(1)
      led2 = pyb.LED(2)
      led3 = pyb.LED(3)
          time.sleep_ms(50)
          dis=distance.read()
          if 610<dis<640:
              data="0"
              data_out = json.dumps(set(data))
              uart.write(data_out +'\n')
              print('you send:',data_out)
          for r in img.find_rects(threshold = 25000):
              if r.w()>r.h():
                  if 470<dis<490:
                      data="1"
                  elif 320<dis<355:
                      data="2"
              elif r.w()<r.h():
                  if 470<dis<490:
                      data="3"
                  elif 320<dis<355:
                      data="4"
      #include <SoftwareSerial.h>
      SoftwareSerial softSerial(10, 11); // RX, TX
      void setup()
        softSerial.begin(9600);
        Serial.begin(9600);
      void loop()
        if(softSerial.available())
          String s = detectString();
           Openmv(s);
      String detectString()
        while(softSerial.read() != '{');
        return(softSerial.readStringUntil('}'));
      void Openmv(String s)
          if(s[1]=='0')
           Serial.print('0');
           Serial.print('\n');
          if(s[1]=='1')
           Serial.print('1');
           Serial.print('\n');
          if(s[1]=='2')
           Serial.print('2');
           Serial.print('\n');
           if(s[1]=='3')
           Serial.print('3');
           Serial.print('\n');
           if(s[1]=='4')
           Serial.print('4');
           Serial.print('\n');
    • 此回复已被删除!
    • https://singtown.com/learn/50539/
      先按照视频步骤测试测距扩展板
