  • 在EDGE impulse上训练的文件为什么不能在openmv运行,三个文件都上传了到内存卡上了
      net = None
      labels = None
      except Exception as e:
          print(e)
          print(clock.fps(), "fps")![0_1657457855310_微信图片_20220710205657.png](https://fcdn.singtown.com/0cec91a9-5b1d-4282-b348-afb926e6f3ea.png)
    • OpenMV4的RAM不够.只能在OpenMV4 Plus上运行.
