有扫描二维码的程序并且可以和32串口通信,并且现在云台经过修改可以追踪二维码,可以把两个代码结合起来输出二维码内容吗?
1.扫码程序
from pyb import UARTuart = UART(3, 115200)
sensor.set_framesize(sensor.QQVGA) # can be QVGA on M7...
sensor.skip_frames(30)
print(code)
FH= bytearray([0xb3,0xb3])
uart.write(FH)
uart.write(code.payload())
FH = bytearray([0x0d,0x0a])
uart.write(FH)
time.sleep_ms(1000)2.云台追踪二维码程序
import sensor, image, timefrom pid import PID
from pyb import Servopan_servo=Servo(1)
tilt_servo=Servo(2)pan_servo.calibration(500,2500,500)
tilt_servo.calibration(500,2500,500)red_threshold = (13, 49, 18, 61, 6, 47)
#tilt_pid = PID(p=0.1, i=0, imax=90)#在线调试使用这个PIDsensor.reset() # Initialize the camera sensor.
clock = time.clock() # Tracks FPS.def find_max(blobs):
return max_blobwhile(True):
img = sensor.snapshot() # Take a picture and return the image.blobs = img.find_qrcodes() if blobs: max_blob = find_max(blobs) pan_error = max_blob[0]+max_blob[2]/2-img.width()/2 tilt_error = max_blob[1]+max_blob[3]/2-img.height()/2 print("pan_error: ", pan_error) img.draw_rectangle(max_blob.rect()) # rect img.draw_cross(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2)) # cx, cy pan_output=pan_pid.get_pid(pan_error,1)/2 tilt_output=tilt_pid.get_pid(tilt_error,1) print("pan_output",pan_output) pan_servo.angle(pan_servo.angle()+pan_output) tilt_servo.angle(tilt_servo.angle()-tilt_output)
你直接调用uart.write就完事了啊
