  • 追踪小车里,让小车固定一定范围寻找目标,加入pyb.delay之后相机也延迟了怎么解决
    • # Blob Detection Example
      import car
      led = pyb.LED(3)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      sensor.skip_frames(50) # Let new settings take affect.
      green_threshold   = (22, 85, -66, -28, -29, 65)
      #green_threshold   = (0, 16, 12, 33, -1, 24)
      size_threshold = 2000
      x_pid = PID(p=0.5, i=1, imax=0)
      h_pid = PID(p=0.03, i=0.1, imax=0)
              print("x error: ", x_error)
              for b in blobs:
              img.draw_cross(max_blob[5], max_blob[6]) # cx, cya
              print("h_output",h_output)
              car.run(10,0)
              pyb.delay(1500)
              car.run(-10,0)
              pyb.delay(1500)
    • 解决办法:再死循环里,使用pyb.millis()查询运行的时间,然后判断,而不使用delay。
      https://docs.singtown.com/micropython/zh/latest/openmvcam/library/pyb.html?highlight=millis#pyb.millis
    • 还是一样的
      import car
      led = pyb.LED(3)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
              for b in blobs:
              #pyb.delay(1500)
              #car.run(-10,0)
              #pyb.delay(1500)
              start = pyb.millis()
              #while pyb.elapsed_millis(start) > 10:
                  #car.run(-10,0)
                  ##start = pyb.millis()
              ##else:
                  ##car.run(-10,0)
              while pyb.elapsed_millis(start) < 2000:
                  car.run(10,0)
              while pyb.elapsed_millis(start) < 4000:
                  car.run(-10,0)
    • @kidswong999 也是一样😭
      import car
      led = pyb.LED(3)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
              for b in blobs:
              #pyb.delay(1500)
              #car.run(-10,0)
              #pyb.delay(1500)
                  #car.run(-10,0)
              ##else:
                  ##car.run(-10,0)
                  car.run(10,0)
                  car.run(-10,0)
      import car
      led = pyb.LED(3)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
      time.sleep_ms(100)
      led.on()
      time.sleep_ms(150)
      led.off()
              last_time = pyb.millis()
              for b in blobs:
              if pyb.elapsed_millis(last_time) % 2000 > 1000:
                  car.run(10,0)
              else
                  car.run(-10,0)
      思路就是不用while 用if,然后每次找到色块后更新时间。
