openMV通过串口向arduino传输信号,如果arduino启用I2C结果是串口用不了。
openMv的代码
import sensor, image, time import json from pid import PID from pyb import Servo from pyb import UART sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(10) sensor.set_auto_whitebal(False) clock = time.clock() uart = UART(1, 9600) green_threshold = (98, 42, -17, 2, -34, -14) size_threshold = 2000 x_pid = PID(p=0.5, i=1, imax=100) h_pid = PID(p=0.05, i=0.1, imax=50) def find_max(blobs): max_size=0 for blob in blobs: if blob[2]*blob[3] > max_size: max_blob=blob max_size = blob[2]*blob[3] return max_blob while(True): clock.tick() img = sensor.snapshot() blobs = img.find_blobs([green_threshold]) if blobs: max_blob = find_max(blobs) x_error = max_blob[5]-img.width()/2 h_error = max_blob[2]*max_blob[3]-size_threshold print("x error: ", x_error) img.draw_rectangle(max_blob[0:4]) img.draw_cross(max_blob[5], max_blob[6]) x_output=x_pid.get_pid(x_error,1) h_output=h_pid.get_pid(h_error,1) pcx=-h_output-x_output pcy=-h_output+x_output data={ "cx":pcx, "cy":pcy} data_out = json.dumps(data) uart.write(data_out +'\n') else: data={ "cx":50, "cy":-50} data_out = json.dumps(data) uart.write(data_out +'\n')
arduino的代码
#include <Wire.h> #include "QGPMaker_MotorShield.h" #include <ArduinoJson.h> QGPMaker_MotorShield AFMS = QGPMaker_MotorShield(); //QGPMaker_Servo *Servo4 = AFMS.getServo(3); QGPMaker_DCMotor *DCMotor_2 = AFMS.getMotor(2); QGPMaker_DCMotor *DCMotor_4 = AFMS.getMotor(4); QGPMaker_DCMotor *DCMotor_1 = AFMS.getMotor(1); QGPMaker_DCMotor *DCMotor_3 = AFMS.getMotor(3); volatile int cx=0; volatile int cy=0; volatile char z=0; String json=""; float leftspeed=0; float rightspeed=0; void setup(){ AFMS.begin(50); Serial2.begin(9600); Serial.begin(9600); } void loop(){ if (Serial2.available() > 0) { z = char(Serial2.read()); json = String(json) + String(z); if (z == '}') { DynamicJsonDocument doc(200); //声明一个JsonDocument对象 deserializeJson(doc, json); JsonObject obj = doc.as<JsonObject>(); float cx = doc["cx"]; float cy = doc["cy"]; if (cx!=0&&cy!=0) { leftspeed=cx; rightspeed=cy; Serial.print("cx = "); Serial.print(cx); Serial.print("cy = "); Serial.println(cy); } json = ""; } } //run1(leftspeed,rightspeed); if (leftspeed < 0){ DCMotor_1->run(BACKWARD); DCMotor_2->run(BACKWARD); }else{ DCMotor_1->run(FORWARD); DCMotor_2->run(FORWARD);} DCMotor_1->setSpeed(int(abs(leftspeed))); DCMotor_2->setSpeed(int(abs(leftspeed))); if (rightspeed < 0){ DCMotor_3->run(BACKWARD); DCMotor_4->run(BACKWARD); }else{ DCMotor_3->run(FORWARD); DCMotor_4->run(FORWARD); } DCMotor_3->setSpeed(int(abs(rightspeed))); DCMotor_4->setSpeed(int(abs(rightspeed))); }
我没看懂,你的意思是Arduno上I2C和uart冲突?看上去是Arduino的问题,而不是OpenMV的问题。
