  • 代码没问题啊为啥这样啊,代码烧不进去,白屏
    • # Untitled - By: STM32 -  5月 19 2021
      import sensor, image,time,lcd
      from pyb import UART,Timer,LED
      sensor.set_framesize(sensor.QVGA)#320*240
      sensor.skip_frames()
      sensor.set_auto_whitebal(False)      #关闭白平衡
      sensor.set_auto_gain(False)          #关闭自动增益
      lcd.init()                           #Initialize the lcd screen.
      uart = UART(3,115200,8,None,1)       #创建串口对象
      data = []
      LED_Red = LED(1)
      LED_Green = LED(2)
      LED_Blue = LED(3)
      tim = Timer(4,freq=1)              # create a timer object using timer 4
      #tim.callback(tick)
      tim.deinit()
      FlagOK = 0
      show_numTab = ["0","1","2","3","4","5","6","7","8","9"]
      num = 0
      returnData = [0x55,0x02,0x92,0x02,0x02,0x00,0x00,0xBB]  #识别失败
      runData    = [0x55,0x02,0x92,0x03,0x02,0x00,0x00,0xBB]  #正在识别
      #定时器回调函数
      def tick(timer):            # we will receive the timer object when being called
          global FlagOK,num,returnData
          print("Timer callback")
          num = num-1
          if(num == 0):
              num = 9
              FlagOK = 2
              tim.deinit()
      #串口发送函数
      def USART_Send(src,length):
          for i in range(length):
              uart.writechar(src[i])
      #   二维码识别,并返回识别结果
      def Color_Check(srcbuf):
          global FlagOK,num
          if(FlagOK == 1):
              img.draw_string(100, 180,"open"+show_numTab[num],color=[255,0,0])
                      FlagOK = 0
                      tim.deinit()
                      print(code)
                      qr_Tab = code.payload()
                      uart.writechar(0x55)
                      uart.writechar(0x02)
                      uart.writechar(0x92)
                      uart.writechar(0x01)
                      uart.writechar(len(qr_Tab))
                      for qrdata in qr_Tab:
                          uart.writechar(ord(qrdata))
                      uart.writechar(0xBB)
          if(FlagOK == 2):
              for rdata in returnData:
                  uart.writechar(rdata)
              FlagOK = 0
          if(uart.any()):
              data = uart.read(8)
              if( len(data) >= 8):
                  if((data[0] == 0x55)&(data[1] == 0x02)&(data[7] == 0xBB)):
                      if(data[2] == 0x91):
                          print("识别小球")
                      if(data[2] == 0x92):
                          print("识别二维码")
                          if(data[3] == 0x01):    #启动识别
                              if(FlagOK == 0):
                                  FlagOK = 1
                                  num = 9
                                  print("开始识别")
                                  tim.callback(tick)
                                  print("正在识别")
                                  for rdata in runData:
                                      print(rdata)
                          if(data[3] == 0x02):
                              print("停止识别")
                              FlagOK = 2
                              tim.deinit()       #定时器停止
          Color_Check(data)
          img.draw_string(110, 40,"qr_CodeV1.0",color=[0,0,255])
          lcd.display(img)
    • 1_1653957725056_QQ图片20220531084146.jpg 0_1653957725055_QQ图片20220531084140.jpg 开始上传的时候花屏,然后报错
    • 这个是盗版的,我没办法处理,请联系卖家处理。
