在形状被遮挡后识别颜色,环境改变后识别颜色怎么解决
import sensor, image, time, math # Color Tracking Thresholds (L Min, L Max, A Min, A Max, B Min, B Max) # The below thresholds track in general red/green things. You may wish to tune them... thresholds = [(0, 20, -18, 127, -8, 22), # generic_red_thresholds -> index is 0 so code == (1 << 0) (0, 60, -18, -48, 22, 127), (0, 50, 2, 127, 2, 127)] # generic_green_thresholds -> index is 1 so code == (1 << 1) # Codes are or'ed together when "merge=True" for "find_blobs". #roi=(20,20,20,20) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.HQQVGA) sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must be turned off for color tracking sensor.set_auto_whitebal(False) # must be turned off for color tracking clock = time.clock() # Only blobs that with more pixels than "pixel_threshold" and more area than "area_threshold" are # returned by "find_blobs" below. Change "pixels_threshold" and "area_threshold" if you change the # camera resolution. "merge=True" must be set to merge overlapping color blobs for color codes. def yanse(): for blob in img.find_blobs(thresholds, pixels_threshold=100, area_threshold=100, merge=True): if blob.code() == 1: # r/g code == (1 << 1) | (1 << 0) print("红色") ys=0 elif blob.code() == 2: # r/g code == (1 << 1) | (1 << 0) print("绿色") ys=1 elif blob.code() == 4: # r/g code == (1 << 1) | (1 << 0) print("黑色") ys=2 else: print("无色") while(True): clock.tick() img = sensor.snapshot() for r in img.find_rects(threshold = 1000): img.draw_rectangle(r.rect(), color = (255, 0, 0)) roi1=r.rect() yanse() print("矩形") jx=1 print("FPS %f" % clock.fps()) for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2): img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0)) roi1=(c.x(), c.y(), c.r()) yanse() print("圆形") yx=2
环境改变了,颜色肯定会变,把颜色阈值调大一些。
要求是要加条件,进行判断如果环境改变,输出形状,如果形状被遮挡,输出颜色
