  • 麻烦问一下,运行老是出现图片上的提示,这是什么问题
      import sensor, image, time, lcd
      green_threshold   = (41, 66, -61, -27, 8, 43)
      red_threshold   = (41, 61, 42, 127, -128, 127)
      yellow_threshold   = ( 60 ,10,-15,20,30,80)
      sensor.set_hmirror(True)
      sensor.set_vflip(True)
      sensor.set_framesize(sensor.QQVGA2)
      sensor.skip_frames(10)
      uart = UART(3, 9600)
             if blob.pixels() > max_size:
                  max_size = blob.pixels()
          blobs0 = img.find_blobs([green_threshold])
          blobs1 = img.find_blobs([red_threshold])
          blobs2 = img.find_blobs([yellow_threshold])
          if blobs0:
           max_blob=find_max(blobs0)
           img.draw_string(100,100, 'x=' + str(blobs0.cx()), color=(0,0,0))
           img.draw_string(100,120, 'y=' + str(blobs0.cy()), color=(0,0,0))
           data="0"
           data_out = json.dumps(set(data))
           uart.write(data_out +'\n')
           print('you send:',data_out)
          elif blobs1:
           max_blob=find_max(blobs1)
           data="1"
          elif blobs2:
           max_blob=find_max(blobs2)
           data="2"
              print('not found','4')
          lcd.display(img) # Take a picture and display the image.
    • 40行:blobs0.cx() 改为max_blob.cx()
      41行:blobs0.cy() 改为max_blob.cy()
