  • 想请问一下,在运行一下代码时出现MemorryError
    • 想请问一下,在运行一下代码时出现MemorryError: memory alloction failed,allocating 115190bytes?我的本意是,设备在接收指令时截取2560x1440的图片,通过wifi模块的TCP模式传输给PC端,现在在设备里将图片数据赋值给一个变量,然后报了这个错误,所以想请教一下这个问题出现的原因,以及如果我要传输高质量图片我要怎么样传输图片数据,跪求了QAQ
      import pyb
      from pyb import Pin, Timer, UART
      # Camera ser
      sensor.set_framesize(sensor.QHD)   # Set frame size to QVGA (320x240)
      sensor.skip_frames(time = 100)     # Wait for settings take effect.
      def info_print():
          print("Image shape is ",(sensor.width(),sensor.height()))
          print("sensor.get_fb()", sensor.get_fb())
          print("sensor.get_id()", sensor.get_id())
          print("sensor.get_framesize()", sensor.get_framesize())
          print("sensor.OV5640", sensor.OV5640)
      info_print()
      red_led.on()
      i = 0
          #print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
                                           #to the IDE. The FPS should increase once disconnected.
          #uart.write("Hello World!\r")
          cframe = img.compressed(quality=10)
          i += 1
          if i == 10:
              print("cframe = ", cframe)
          time.sleep_ms(200)
    • 在最后添加一句
      del(cframe)
      就不会报错了
