openmv打开uart脱机运行为什么会自动断开?
你好,
我想用通过uart使openmv传数据到stm32, 连接电脑ide的时候是正常运行的,stm32也能接收到数据。但是一旦脱机运行,openmv运行几秒钟之后就会闪两下红灯自动断开。我尝试过注释掉uart代码,再脱机运行又能正常工作了。所以我不知道是不是uart有什么问题使openmv断开。
下面是我的代码:
import sensor, image, time, math from pid import PID from pyb import UART, LED sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) clock = time.clock() rho_weight = 1 theta_weight = 1 count = 0 w = 80 h = 60 mid_x = w/2 mid_y = h/2 gain = 5 uart = UART(3, 115200, timeout_char = 1000) green_led = LED(2) def pooling_filter(img): img.midpoint_pool(2, 2,bias=0.5) img.binary([(120,130)]) img.midpoint_pool(2, 2,bias=0.5) img.binary([(120,130)]) def find_middle_line(img): try: pooling_filter(img) line = img.get_regression([(240,255)], robust = True) img.draw_line(line.line(), color = 139,thickness=2) rho_error, theta_error = line_to_theta_and_rho(line.rho(),line.theta()) return rho_error, theta_error except: return 0,0 def line_to_theta_and_rho(rho,theta): if rho < 0: trans_rho = -rho trans_theta = theta + 180 else: trans_rho = rho trans_theta = theta cos_trans_theta = math.cos(math.radians(trans_theta)) sin_trans_theta = math.sin(math.radians(trans_theta)) distance = abs(mid_x*cos_trans_theta + mid_y*sin_trans_theta - trans_rho) if trans_theta == 90 or trans_theta == 270: distance_error = theta_error = 0 elif (trans_rho-mid_y*sin_trans_theta)/cos_trans_theta > mid_x: distance_error = distance if theta > 90: theta_error = theta - 180 else: theta_error = theta else: distance_error = -distance if theta > 90: theta_error = theta - 180 else: theta_error = theta return distance_error, theta_error while(True): clock.tick() img = sensor.snapshot() img.find_edges(image.EDGE_CANNY, threshold=(150,190)) rho_error,theta_error = find_middle_line(img) if count != 10: if count == 0: rho_error_sum = theta_error_sum = 0 rho_error_sum += rho_error theta_error_sum += theta_error count += 1 continue else: rho_error_sum /= 10 theta_error_sum /= 10 count = 0 rho_pid = PID(p=0.40, i=0.1, d=0, imax=10) theta_pid = PID(p=0.25, i=0.1, d=0, imax=10) rho_output = rho_pid.get_pid(rho_error_sum,1) theta_output = theta_pid.get_pid(theta_error_sum,1) output = gain*int(rho_weight*rho_output+theta_weight*theta_output) if output > 0: output = 'A' else: output = 'B' uart.write(str(output)+'\r\n') green_led.on() print('output=',output)
@g4kx 在 openmv打开uart脱机运行为什么会自动断开? 中说:
脱机运行,哪里断开?是说OpenMV会重启?
我脱机运行这个代码没有出现闪红灯的现象,你脱机运行时通过什么供电的?把全部电路都拔掉,只通过USB供电试试。
