  • OPENMV4 H7 PLUS使用LCD历程LCD屏幕无法正常显示画面
    • # LCD Example
      # Note: To run this example you will need a LCD Shield for your OpenMV Cam.
      # The LCD Shield allows you to view your OpenMV Cam's frame buffer on the go.
      import sensor, image, lcd
      sensor.set_framesize(sensor.QQVGA2) # Special 128x160 framesize for LCD Shield.
          lcd.display(sensor.snapshot()) # Take a picture and display the image.
    • 我测试没问题,要么是没焊接插针,或者是硬件坏了,可以把OpenMV和LCD扩展板一起寄回维修。
