  • 代码运行了,但这个舵机就通电动一下,不能识别转向。
      # These pins control our direction while the other PWN pins
      # below control the speed. The direction for each motor
      # is set by an H-Bridge where A0/1 are the two sides of
      # one H-Bridge driver. B0/1 are another H-Bridge.
      pinADir0 = pyb.Pin('P3', pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
      pinADir1 = pyb.Pin('P2', pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
      pinBDir0 = pyb.Pin('P1', pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
      pinBDir1 = pyb.Pin('P0', pyb.Pin.OUT_PP, pyb.Pin.PULL_NONE)
      # Dir0/1 must be not equal to each other for forward or backwards
      # operation. If they are equal then that's a brake operation.
      # If they are not equal then the motor will spin one way other the
      # other depending on it's hookup and the value of dir 0.
      pinADir0.value(0)
      pinADir1.value(1)
      pinBDir0.value(0)
      pinBDir1.value(1)
      # Create a timer object running at 1KHz which which will power the
      # PWM output on our OpenMV Cam. Just needs to be created once.
      tim = pyb.Timer(4, freq=1000)
      # Use the timer object to create two PWM outputs on the OpenMV Cam.
      # These timers control the speed of the motors. You will be setting
      # the PWM percentage of these timers repeatedly in your loop.
      chA = tim.channel(1, pyb.Timer.PWM, pin=pyb.Pin("P7"))
      chB = tim.channel(2, pyb.Timer.PWM, pin=pyb.Pin("P8"))
      from pyb import Servo
      pan_servo=Servo(1)
      red_threshold  = (20, 60, 78, -127, 57, 8)
          chA.pulse_width_percent(80)
          chB.pulse_width_percent(80)
    • https://book.openmv.cc/example/02-Board-Control/servo-control.html
      测试这个代码,舵机是否能动?
    • 我用了舵机扩展板,扩展板那个可以
    • 你代码有问题。
      chA ,chB和舵机引脚冲突了。
