  • 串口输出坐标,为什么会失败
      from machine import UART
      uart = UART(2, baudrate=115200)
      uart_num = 0
      uart_array = [48,49,50,51,52,53,54,55,56,57]
      uart.write(uart_num.to_bytes(1, 'little'))
      uart.write(bytearray(uart_array))
      uart.write(bytearray([0x41]))       # 发送一个十六进制数据
          uart_num = uart.any()
          # Circle objects have four values: x, y, r (radius), and magnitude. The
          # magnitude is the strength of the detection of the circle. Higher is
          # better...
          # `threshold` controls how many circles are found. Increase its value
          # to decrease the number of circles detected...
          # `x_margin`, `y_margin`, and `r_margin` control the merging of similar
          # circles in the x, y, and r (radius) directions.
          # r_min, r_max, and r_step control what radiuses of circles are tested.
          # Shrinking the number of tested circle radiuses yields a big performance boost.
          for c in img.find_circles(threshold = 2000, x_margin = 10, y_margin = 10, r_margin = 10,
              img.draw_circle(c.x(), c.y())
          if(uart_num):
              uart_str = uart.read(uart_num)
              uart.write(uart_str)
    • 我运行代码,报错是ValueError: UART(2) doesn't exist,请提供具体的硬件型号。
    • 改成串口2了,那再怎么版
    • @2nc3 你为什么用串口2,硬件上就没有串口2啊。
      先按照视频测试。
      https://singtown.com/learn/50235/
    • 说错了,用的是三
    • 就是有没有办法将遍历出来的圆的中心坐标一个个地表示出来,
    • @2nc3 看视频了吗,视频里有怎么拼装字符串。
