  • 怎样避开json实现传出多个圆坐标
    • from machine import UART
      import json, sensor, image, time
      uart = UART(2, baudrate=115200)
          # Circle objects have four values: x, y, r (radius), and magnitude. The
          # magnitude is the strength of the detection of the circle. Higher is
          # better...
          # `threshold` controls how many circles are found. Increase its value
          # to decrease the number of circles detected...
          # `x_margin`, `y_margin`, and `r_margin` control the merging of similar
          # circles in the x, y, and r (radius) directions.
          # r_min, r_max, and r_step control what radiuses of circles are tested.
          # Shrinking the number of tested circle radiuses yields a big performance boost.
          circles = img.find_circles(threshold = 2000, x_margin = 10, y_margin = 10, r_margin = 10,
                  r_min = 2, r_max = 100, r_step = 2)
          uart.write("111")
          if circles:
              print('sum :', len(circles))
              output_str = json.dumps(circles)
              for c in circles:
                 img.draw_circle(c.x(), c.y())
              print('you send:',output_str)
              uart.write(output_str+'\n')
