  • 追踪小球程序,p7p8引脚输出低电平,pwm不应该是高电平吗,只有输出1v多点。
    • import car
          car.run(50,50)
      from pyb import Pin, Timer
      ain1 = Pin('P0', Pin.OUT_PP)
      ain2 = Pin('P1', Pin.OUT_PP)
      bin1 = Pin('P2', Pin.OUT_PP)
      bin2 = Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      if inverse_left==True:
      left_speed=(-left_speed)
      if inverse_right==True:
      right_speed=(-right_speed)
      if left_speed < 0:
          ain1.low()
          ain2.high()
          ain1.high()
          ain2.low()
      ch1.pulse_width_percent(int(abs(left_speed)))
      if right_speed < 0:
          bin1.low()
          bin2.high()
          bin1.high()
          bin2.low()
      ch2.pulse_width_percent(int(abs(right_speed)))
    • 你要用示波器看,就会看到占空比不同的方波。
