  • 这段代码怎么调整,我的目的是把它的数据发送到arduino端的串口监视器器
    • # Blob Detection and uart transport
      yellow_threshold   = (65, 100, -10, 60, 24, 51)
      sensor.reset() # 初始化摄像头
      sensor.skip_frames(10) # 跳过10帧,使新设置生效
      sensor.set_auto_whitebal(False)               # Create a clock object to track the FPS.
      ROI=(80,30,15,15)
          #color_l=statistics.l_mode()
          color_a=statistics.a_mode()
          output_str="" % (statistics.a_mode())
          #color_b=statistics.b_mode()
          print(color_a)
          img.draw_rectangle(ROI)
              uart.write(statistics.a_mode())
    • uart.write(str(statistics.a_mode()))
      另外你缩进不对。
