  • 连接延长线为什么会报错,不使用延长线是可以正常使用的
    • import sensor, image, time,pyb
      from pyb import Pin
      from pyb import LED
      red_threshold   = (54, 65, 54, 79, 16, 48)
      blue_threshold = (42, 65, 5, 48, -87, -33)
      green_threshold = (44, 82, -54, 1, -6, 24)
      sensor.skip_frames(10)
      led1 = pyb.LED(1)
      led2 = pyb.LED(2)
      led3 = pyb.LED(3)
      p3 = Pin('P0', Pin.OUT_PP)
      p4 = Pin('P1', Pin.OUT_PP)
      p5 = Pin('P2', Pin.OUT_PP)
      p6 = Pin('P3', Pin.OUT_PP)
          blobs1 = img.find_blobs([red_threshold],roi=(270,5,150,250), pixels_threshold=150, area_threshold=200,merge=True)
          blobs2 = img.find_blobs([blue_threshold],roi=(270,5,150,250), pixels_threshold=150, area_threshold=200,merge=True)
          blobs3 = img.find_blobs([green_threshold],roi=(270,5,150,250),pixels_threshold=150, area_threshold=200,merge=True)
          img.lens_corr(1.8)
              print(code)
              Data = code.payload()
              if Data == '357':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.low()
                      p5.low()
                      p6.high()
                      i=i+1
                      print(i)
              elif Data == '358':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.low()
                      p5.high()
                      p6.low()
                      i=i+1
                      print(i)
              elif Data == '367':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.low()
                      p5.high()
                      p6.high()
                      i=i+1
                      print(i)
              elif Data == '368':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.high()
                      p5.low()
                      p6.low()
                      i=i+1
                      print(i)
              elif Data == '457':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.high()
                      p5.low()
                      p6.high()
                      i=i+1
                      print(i)
              elif Data == '458':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.high()
                      p5.high()
                      p6.low()
                      i=i+1
                      print(i)
              elif Data == '467':
                  i=0
                  while(i<1000):
                      p3.low()
                      p4.high()
                      p5.high()
                      p6.high()
                      i=i+1
                      print(i)
              elif Data == '468':
                  i=0
                  while(i<1000):
                      p3.high()
                      p4.low()
                      p5.low()
                      p6.low()
                      i=i+1
                      print(i)
          if blobs1:
              for b in blobs1:
                  img.draw_rectangle(b[0:4])
                  print('red')
                  led1.on()
                  led2.off()
                  led3.off()
                  p3.high()
                  p4.low()
                  p5.low()
                  p6.high()
          elif blobs2:
              for b in blobs2:
                  print('blue')
                  led1.off()
                  led2.off()
                  led3.on()
                  p3.high()
                  p4.low()
                  p5.high()
                  p6.low()
    • 固件与IDE也升级到最新版本,依然报错
    • 建议把OpenMV和延长线都寄回检查维修。
