  • Warning: I2C(-1, ...) is deprecated
      import sensor, image, time,math,pyb
      from pyb import Servo
      from pyb import millis
      from math import pi, isnan
      from pyb import Pin, Timer
      import mlx90614
      #import time
      from machine import Pin,I2C
      #import sensor, image, time,math,pyb
      from pyb import UART,LED
      #import json
      import ustruct
      class PID:
      _RC = 1/(2 * pi * 20)
      def init(self, p=0, i=0, d=0, imax=0):
      self._kp = float(p)
      self._ki = float(i)
      self._kd = float(d)
      self._imax = abs(imax)
      tnow = millis()
      dt = tnow - self._last_t
      output = 0
      dt = 0
      self.reset_I()
      self._last_t = tnow
      output += error * self._kp
      derivative = 0
      self._last_derivative = 0
      derivative = self._last_derivative +
      ((delta_time / (self._RC + delta_time)) *
      self._last_error = error
      output *= scaler
      output += self._integrator
      return output
      def reset_I(self):
      self._integrator = 0
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      pan_pid = PID(p=0.05, i=0, imax=10)
      tilt_pid = PID(p=0.05, i=0, imax=10)
      #light = Timer(2, freq=50000).channel(1, Timer.PWM, pin=Pin("P6"))
      #light.pulse_width_percent(8)
      #light.pulse_width_percent(10)
      sensor.set_contrast(3)
      sensor.set_gainceiling(32)
      sensor.set_vflip(True)
      sensor.skip_frames(10)
      sensor.set_auto_whitebal(True)
      sensor.set_auto_exposure(True)
      sensor.set_auto_gain(True)
      uart = UART(1, 115200)
      i2c = I2C(sda=Pin('P5'), scl=Pin('P4'),freq=100000)
      temp = mlx90614.MLX90614(i2c)
      data=bytearray([0xfd,0x00,0x0e,0x01,0x01,0xCE,0xC2,0xB6,0xC8,0xB8,0xDF,0xC7,0xEB,0xD7,0xA2,0xD2,0xE2])
      blobs = img.find_features(face_cascade, threshold=0.2, scale=1.1)
      img.draw_rectangle(max_blob,[255,0,0],thickness=5)
      img.draw_cross(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/4),[255,0,0])
      tilt_servo.angle(tilt_servo.angle()+tilt_output)
      print('ObjTemp:'+str('%.2f'%temp.ObjectTemp())+'C')
      print('AmbTemp:'+str('%.2f'%temp.AmbientTemp())+'C')
      if temp.ObjectTemp() >= 34.5:
      print("temp");
      uart.write(data)
    • 没看到有错误。你有什么问题?
    • 图片最后一行,是不是提示i2c被占用了?
    • 最后一行是warning,不是错误。不是提示i2c被占用。
