  • 如何识别矩形圆形面积,我识别圆形有时候会打印矩形,怎么更改一下。
      black_threshold = (0, 20, -18, 127, -8, 22)      #black
      green_threshold = (0, 70, -128, -28, 22, 127)  #green
      red_threshold =   (0, 50, -128, 127, 12, 127) #red
      #识别形状颜色
          for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2):
              output_str="[%d,%d,%d]" % (c.x(),c.y(),c.r())
              print("形状:圆形",output_str)
              uart.write(output_str+'\r\n')
              statistics=img.get_statistics(roi = (c.r(),  c.r(), 2 * c.r(), 2 * c.r()))
              blobs = img.find_blobs([red_threshold,green_threshold,black_threshold],roi=(c.r(),  c.r(), 2 * c.r(), 2 * c.r()))
                   pass
              output_str="[%d,%d,%d,%d]" % (r.x(),r.y(),r.w(),r.h())
              print("形状:矩形",output_str)
              area = r.rect()
              blobs = img.find_blobs([red_threshold,green_threshold,black_threshold],roi=area)
                   pass
    • 把所有的draw_rectangle删除,否则会影响后面的查找矩形。
