  • 在lcd上显示了数据,但由于直接应用的数组 数值略长 如何实现数组分离和得到除法后的结果
      import sensor, image, time, tf,lcd
      sensor.skip_frames(time=2000)
      lcd.init()       # Let the camera adjust.
      mobilenet = "openmv_classify.tflite"
      labels = [line.rstrip() for line in open("labels.txt")]
      class_num = len(labels)
          for obj in tf.classify(mobilenet, img, min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
              output = obj.output()
              for i in range(class_num):
                  print("%s = %f" % (labels[i], output[i]))
          print(clock.fps(), "fps")
          img.draw_string(10,110, str(output))              # 文字输入 固定
          img.draw_string(10,100, "no mask            msak")
          lcd.display(img)
    • >>> a = "0.123456789"
      >>> a[:5]
      '0.123'
    • 我尝试了这样output = obj.output()[:3],无变化
      又尝试了a=output【0】 b=a【:5】 img.draw_string(10,110, str(b))显示错误
    • output_str = ""
      for n in output:
          output_str += str(n)[:5]
      img.draw_string(10,110, output_str)
