  • ‘int’ obiect isn‘t subscriptable怎么回事啊?
    • # Blob Detection Example
      import car
      green_threshold   = (7, 58, -54, -20, -4, 40)
      size_threshold = 20000
      template = image.Image("/1.pgm")
          blobs = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
              x_error = max_blob[0]+max_blob[2]/2-img.width()/2
              print("x error: ", x_error)
              for b in blobs:
              img.draw_cross(int(max_blob[0]+max_blob[2]/2),int(max_blob[1]+max_blob[3]/2)) # cx, cy
              print("h_output",h_output)
              car.run(18,-18)
    • 原因:find_template只会返回一个矩形,而不是多个。
      import car
          max_blob = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
          if max_blob:
              for b in blobs:
              pass
              car.run(18,-18)
    • @kidswong999 该怎么修改呢 find_template用其他的函数替代还是用一个循环?
    • @nbio_1647004161 我上面就是修改后的代码
