为什么会出现reset failed和capture failed 啊
import sensor, image, time, pyb from pyb import Pin sensor.reset() sensor.set_pixformat(sensor.RGB565) # 灰度更快 sensor.set_framesize(sensor.QQVGA) sensor.skip_frames(time = 2000) clock = time.clock() led1 = pyb.LED(1) while(True): clock.tick() img = sensor.snapshot() img = sensor.snapshot().lens_corr(1.8) for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2): img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0)) print(c) for r in img.find_rects(threshold = 10000): img.draw_rectangle(r.rect(), color = (255, 0, 0)) print(r) print("FPS %f" % clock.fps()) print("FPS %f" % clock.fps()) circles=img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,r_min = 2, r_max = 100, r_step = 2) rects=img.find_rects(threshold = 10000) if circles: led1.on() time.sleep(3000) led1.off() time.sleep(100) led1.on() time.sleep(3000) led1.off() time.sleep(100) if rects: p_out=Pin('A8',Pin.OUT_PP) p_out.high()
最后的Pin A8是做什么的?应该只用P0~P9
