  • 识别数字后的数据通过串口发送到电脑出现问题
    • 用识别数字例程识别数字,想将输出的数据经串口传送到电脑,代码如下
      sensor.reset()                          # Reset and initialize the sensor.
      sensor.set_contrast(3)
      sensor.set_pixformat(sensor.GRAYSCALE)  # Set pixel format to RGB565 (or GRAYSCALE)
      sensor.set_framesize(sensor.VGA)        # Set frame size to QVGA (320x240)
      sensor.set_windowing((128, 128))        # Set 128x128 window.
      sensor.skip_frames(time = 2000)         # Wait for settings take effect.
      sensor.set_auto_gain(False)
          # NOTE: Uncomment to detect dark numbers on white background
          # img.invert()
          out = img.find_number(roi=(img.width()//2-14, img.height()//2-14, 28, 28))
          img.draw_rectangle((img.width()//2-15, img.height()//2-15, 30, 30))
          if out[1] > 5: # Confidence level
              print("Number: %d Confidence: %0.2f" %(out[0], out[1]))
         uart.write(out[0]'\n')
        time.sleep(1000)
      发现串口部分代码不正确,但不知道要怎么改,求大神指点一二。
    • if out[1] > 5: # Confidence level
          uart.write(out[0]+'\n')
    • uart.write(str(out[0])+'\n')
