  • 请问iic和串口uart不能同时使用吗,一起用就会报错OSError: [Errno 19] ENODEV
    • # Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script!
      import sensor, image, time, utime
      from machine import I2C
      from pyb import RTC
      from vl53l1x import VL53L1X
      i2c = I2C(2)
      distance = VL53L1X(i2c)
      rtc = RTC()
      rtc.datetime((2021,11,25, 4,20,11, 0, 0))
      uart = UART(3)
      uart.init(115200, timeout_char=1000)
      sensor.skip_frames(time = 2000) # Wait for settings take effect.
          uart.write(img.compressed(quality=50)) # Note: OpenMV Cam runs about half as fast when connected
      #    uart.write("range: mm ", distance.read())
      #    uart.write(rtc.datetime())
          print("range: mm ", distance.read())
          time.sleep_ms(1000)
    • 引脚冲突,你可以用uart1,也就是P0,P1.
      https://singtown.com/product/50812/openmv4-h7-plus/
