为什么我的openmv(cam M4-OV7725)载入机器学习网络文件的时候,内存报分配错误?
# TensorFlow Lite Person Dection Example # # Google's Person Detection Model detects if a person is in view. # # In this example we slide the detector window over the image and get a list # of activations. Note that use a CNN with a sliding window is extremely compute # expensive so for an exhaustive search do not expect the CNN to be real-time. import sensor, image, time, os, tf sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.set_windowing((240, 240)) # Set 240x240 window. sensor.skip_frames(time=2000) # Let the camera adjust. # Load the built-in person detection network (the network is in your OpenMV Cam's firmware). net = tf.load('./mobilenet_small_quant.tflite') labels = ["Angry", "Disgust", "Fear", "Happy", "Sad", "Surprise", "Neutral"] clock = time.clock() while(True): clock.tick() img = sensor.snapshot() # net.classify() will run the network on an roi in the image (or on the whole image if the roi is not # specified). A classification score output vector will be generated for each location. At each scale the # detection window is moved around in the ROI using x_overlap (0-1) and y_overlap (0-1) as a guide. # If you set the overlap to 0.5 then each detection window will overlap the previous one by 50%. Note # the computational work load goes WAY up the more overlap. Finally, for multi-scale matching after # sliding the network around in the x/y dimensions the detection window will shrink by scale_mul (0-1) # down to min_scale (0-1). For example, if scale_mul is 0.5 the detection window will shrink by 50%. # Note that at a lower scale there's even more area to search if x_overlap and y_overlap are small... # default settings just do one detection... change them to search the image... for obj in net.classify(img, min_scale=1.0, scale_mul=0.5, x_overlap=0.0, y_overlap=0.0): print("**********\nDetections at [x=%d,y=%d,w=%d,h=%d]" % obj.rect()) for i in range(len(obj.output())): print("%s = %f" % (labels[i], obj.output()[i])) img.draw_rectangle(obj.rect()) img.draw_string(obj.x()+3, obj.y()-1, labels[obj.output().index(max(obj.output()))], mono_space = False) print(clock.fps(), "fps")
报错信息:MemoryError: memory allocation failed, allocating 156856 bytes MicroPython: v1.15-r57 OpenMV: v4.1.1 HAL: v1.2.8 BOARD: OPENMV3-STM32F765
只能OpenMV 4 Plus上用,你的是OpenMV3
此回复已被删除!
@kidswong999 我去试了一下,tf的库都不行,然后我准备用network神经网络的,但是IDE却提示ImportError: no module named 'nn',没有nn的库,这是什么情况?
edge impulse只能OpenMV 4 Plus上用,你的是OpenMV3,所以用不了。
nn的库早就被删除了,用不了。
