为什么模板匹配 我打印t 是一堆数字 按官方的应该是我的文件名
import time, sensor, image,pyb from image import SEARCH_EX, SEARCH_DS from pyb import UART import ustruct from pyb import LED one=LED(1) #从imgae模块引入SEARCH_EX和SEARCH_DS。使用from import仅仅引入SEARCH_EX, #SEARCH_DS两个需要的部分,而不把image模块全部引入。 clock = time.clock() # Reset sensor sensor.reset() # Set sensor settings sensor.set_contrast(1) #设置对比度 sensor.set_gainceiling(16) #设定增益曲线 sensor.set_framesize(sensor.QQVGA) sensor.set_pixformat(sensor.GRAYSCALE) #串口3定义 uart1 = UART(3,115200) #定义串口3变量 uart1.init(115200, bits=8, parity=None, stop=1) # init with given parameters def sending_data(cx,cy): global uart1; #frame=[0x2C,18,cx%0xff,int(cx/0xff),cy%0xff,int(cy/0xff),0x5B]; #data = bytearray(frame) datasum=ustruct.pack("<bbhhhhb", #格式为俩个字符俩个短整型(2字节) 0x2C, #帧头1 0x12, #帧头2 int(cx), # up sample by 4 #数据1 int(cy), # up sample by 4 #数据1 0x5B) uart1.write(datasum); #必须要传入一个字节数组 #初始模板 templatedemo = ["/1.pgm", "/2.pgm", "/3.pgm", "/4.pgm","/5.pgm", "/6.pgm", "/7.pgm", "/8.pgm"] ##分类模板 templates = (["/3.pgm", "/32.pgm", "/33.pgm", "/34.pgm","/35.pgm", "/36.pgm"], ["/4.pgm", "/42.pgm", "/43.pgm", "/44.pgm","/45.pgm", "/46.pgm"], ["/5.pgm", "/52.pgm", "/53.pgm", "/54.pgm","/55.pgm", "/56.pgm"], ["/6.pgm", "/62.pgm", "/63.pgm", "/64.pgm","/65.pgm", "/66.pgm"], ["/7.pgm", "/72.pgm", "/73.pgm","/74.pgm","/75.pgm", "/76.pgm","/701.pgm","/702.pgm","/703.pgm","/704.pgm","/705.pgm","/706.pgm"], ["/8.pgm","/82.pgm", "/83.pgm", "/84.pgm","/85.pgm", "/86.pgm","/801.pgm","/802.pgm","/803.pgm","/804.pgm","/805.pgm","/806.pgm"]) #8\ imgarray=[0,0,0,0,0,0,0,0] imgarrays=[0,0,0,0,0,0,0,0,0,0,0,0] first=0 cx=0 cy=0 def get_first(img):#病房号识别输入 返回一到八 判断初始模板 #print("get_first") global imgarray r = img.find_template(imgarray[0], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 1 r = img.find_template(imgarray[1], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 2 r = img.find_template(imgarray[2], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 3 r = img.find_template(imgarray[3], 0.7 ,step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 4 r = img.find_template(imgarray[4], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 5 r = img.find_template(imgarray[5], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 6 r = img.find_template(imgarray[6], 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 7 r = img.find_template(imgarray[7], 0.7, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60)) if r: img.draw_rectangle(r) return 8 return 0 '''def isget(num):#判断是否输入成功 if num is not 0: for i in range (num): one.on() print(num) #使用时删除 给自己看的 time.sleep_ms(100) one.off() time.sleep_ms(100) cx = num''' def getimgs(imgarr): i=0 #print("getimgs") for t in imgarr: imgarrays[i]=image.Image((t)) #print(imgarrays[i]) i+=1 return imgarrays def match_img(photos,img):#模板匹配 isget=0 #print("match_img") for t in photos: print("tt",t) r = img.find_template(t, 0.50, step=4, search=SEARCH_EX)#不能将int转换为type if r: img.draw_rectangle(r) isget=1 break else: pass if isget==1: sending_data(0x37,0x12) #55 isget=0 else: sending_data(0x73,0x21) #115 def loadimg(): #导入正常图片八张 #print("loading") i=0 for t in templatedemo: imgarray[i]=image.Image(str(t)) i+=1 return imgarray imgarray=loadimg() #加载初始八张图 while (True): clock.tick() img = sensor.snapshot() if imgarrays[0]!=0: match_img(imgarrays,img)#比对当前帧图片与加载进来的模板库匹配 '''cy=int(img)''' print("y:",cy) else: if first==0: #获取初始图片标志位 first=get_first(img) #first用于判断当前是那张图片 if first is not 0: for i in range (first): one.on() print(first) #使用时删除 给自己看的 time.sleep_ms(100) one.off() time.sleep_ms(100) cx = first#亮灯提醒是否识别到初始图片 print("1:",cx) elif first==1: sending_data(0x10) # 确定是1 elif first==2: sending_data(0x20) #确定是2 elif imgarrays[0]==0: #确定图片缓冲区第一次是空 imgarrays=getimgs(templates[first-3])#load photo 加载图片 执行一次 else:#之后程序只会在这里执行 pass FH = bytearray([0x2C,0x12,cx,cy,0x5B]) print("6:",cx) uart1.write(FH) print("FPS:",clock.fps())#帧率显示
print(t)的值:tt {"w":70, "h":96, "type"="grayscale", "size":6720}
tt {"w":60, "h":68, "type"="grayscale", "size":4080}
tt {"w":60, "h":65, "type"="grayscale", "size":3900}
tt {"w":60, "h":48, "type"="grayscale", "size":2880}
tt {"w":60, "h":53, "type"="grayscale", "size":3180}
tt {"w":60, "h":47, "type"="grayscale", "size":2820}
我的模板匹配为什么打印的是这个。 我目的是为了得到这个扫描到模板的文件名 然后写它在列表的哪个位置 现在它怎么打印这些东西
你的photos是图片数组,不是字符串数组。
@kidswong999 那请问 我该怎么样才能得到一个参数 让它输出的是这个扫描到的数字号 现在我只能知道它是否扫到 。不知道是数字几 传输不出去
