  • capture failed:-4
    • import sensor
      import image
      import network
      import usocket
      import sys
      import sensor
      import image
      import network
      import usocket
      import sys
      import math
      import pyb
      from pyb import LED
      # 变量分配区
      # 绿色追踪
      threshold = [53, 238]
      Frame_Cnt = 0
      fCnt_tmp = [0, 0]
      count = 0
      rangefinder = 0
      # 局部函数定义区
      red_led = LED(1)
      green_led = LED(2)
      blue_led = LED(3)
      ir_led = LED(4)
      def get_rangefinder(uart_line):
              if (len(uart_line) < 8):
                  return 0xFF
              if(uart_line[0] != 0x59):
                  return 0xFF
              if(uart_line[1] != 0x59):
                  return 0xFF
              if(uart_line[2] != None and uart_line[3] != None):
                  return uart_line[3] * 256 | uart_line[2]
          except:
              return 20
              pass
      def ExceptionVar(var):
          data = []
          data.append(0)
          data.append(0)
          if var == -1:
              data[0] = 0
              data[1] = 0
              data[0] = var & 0xFF
              data[1] = var >> 8
          return data
      # 串口3 P4 P5 = TX RX
      # 串口1 P1 P2 = TX RX
      def UART_Send(FormType, Loaction0, Location1, range_finder=0):
          global Frame_Cnt
          global fCnt_tmp
          Frame_Head = [170, 170]
          Frame_End = [85, 85]
          fFormType_tmp = [FormType]
          Frame_Cnt += 1
          if Frame_Cnt > 65534:
              FrameCnt = 0
          fHead = bytes(Frame_Head)
          fCnt_tmp[0] = range_finder & 0xFF
          fCnt_tmp[1] = range_finder >> 8
          # if(range_finder != 0):
          #     fCnt_tmp[1] = range_finder
          fCnt = bytes(fCnt_tmp)
          fFormType = bytes(fFormType_tmp)
          fLoaction0 = bytes(ExceptionVar(Loaction0))
          fLoaction1 = bytes(ExceptionVar(Location1))
          fEnd = bytes(Frame_End)
          FrameBuffe = fHead + fCnt + fFormType + fLoaction0 + fLoaction1 + fEnd
          return FrameBuffe
      # main函数区
      sensor.set_contrast(3)
      #sensor.skip_frames(time = 2000)
      uart_Rangefinder = UART(1, 115200)
      #文件导入特征点
      kpts1 = image.load_descriptor("/desc.orb")
      #img = sensor.snapshot()
      start = pyb.millis()
      while pyb.elapsed_millis(start)<10000:
          kpts2 = img.find_keypoints(max_keypoints=150, threshold=10, normalized=False)
          if kpts2:
              if(match.count()>10):
              P0 = match.x()
              P1 = match.y()
              Type = 306
              print(Type,P0,P1)
              print("no find kpts")
              green_led.off()
              Type = 0xFF
              P0 = -1
              P1 = -1
          uart.write(UART_Send(Type, P0, P1))
          circles = img.find_circles(threshold=4000, x_margin=100,
                                 y_margin=100, r_margin=10, r_min=2, r_max=100, r_step=2)
          if circles:
              green_led.on()
              for circle_ in circles:
                  img.draw_circle(circle_.x(), circle_.y(),
                              circle_.r(), color=(255, 0, 0))
                  img.draw_cross(circle_.x(), circle_.y())
                  P0 = circle_.x()
                  P1 = circle_.y()
                  Type = 202
                  print(Type, P0, P1)
              # uart.write(UART_Send(Type, P0, P1, rangefinder))
              print("no find circle")
              green_led.off()
              Type = 0xFF
              P0 = -1
              P1 = -1
    • 你的代码没有sensor.reset()
      运行hello world有没有问题?
    • 可以运行,但是一个程序可以像上面那样用两个while吗
    • @hmwy 可以,但是下面的死循环永远不会运行。
