  • 更换摄像头识别数字就会卡屏?
    • 使用原来的摄像头识别数字没问题,换成新的摄像头后,其他程序都没变,但是运行时就会卡主,需要重新连接USB才能运行,这是为什么?
    • 提供具体的代码,硬件型号,固件版本,我才能测试。
      # NCC is not all to useful.
      # Always pass UART 3 for the UART number for your OpenMV Cam.
      # The second argument is the UART baud rate. For a more advanced UART control
      # example see the BLE-Shield driver.
      import time, sensor, image
      uart = UART(3,9600)
      uart.init(9600,bits=8,parity=None,stop=1)
      #while(True):
          #uart.write("Hello World!\r")
          #time.sleep_ms(1000)
      # Reset sensor
      # Set sensor settings
      # Load template.
      template4 = image.Image("/4.pgm")
      template5 = image.Image("/5.pgm")
      template6 = image.Image("/6.pgm")
      template7 = image.Image("/7.pgm")
      template8 = image.Image("/8.pgm")
      # Run template matching
          r1 = img.find_template(template1, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r1:
              img.draw_rectangle(r1)
              print(1)
              uart.write("1")
              a=1
          r2 = img.find_template(template2, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r2:
              img.draw_rectangle(r2)
              print(2)
              uart.write("2")
              a=2
          r3 = img.find_template(template3, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r3:
              img.draw_rectangle(r3)
              print(3)
              uart.write("3")
              a=3
          r4 = img.find_template(template4, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r4:
              img.draw_rectangle(r4)
              print(4)
              uart.write("4")
              a=4
          r5 = img.find_template(template5, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r5:
              img.draw_rectangle(r5)
              print(5)
              uart.write("5")
              a=5
          r6 = img.find_template(template6, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r6:
              img.draw_rectangle(r6)
              print(6)
              uart.write("6")
              a=6
          r8 = img.find_template(template1, 0.40, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r8:
              img.draw_rectangle(r8)
              print(8)
              uart.write("8")
              a=8
          r7 = img.find_template(template7, 0.70, step=4, search=SEARCH_EX) #, roi=(10, 0, 60, 60))
          if r7:
              img.draw_rectangle(r7)
              print(7)
              uart.write("7")
              a=7
                  output = json.dumps(a)
                  print(output)
                  uart.write(output)
    • 摄像头是H7 R1的
    • 你最后有一个死循环,永远跳不出。
    • 问题是我#之后显示indentationerror咋 解决
    • @kidswong999 噢解决了感谢!
