  • 识别数字时出现OSError
      代码:# Edge Impulse - OpenMV Image Classification Example
      net = "trained.tflite"
      print(clock.fps(), "fps")
    • 有没有把labels.txt和trained.tflite复制到OpenMV的磁盘里?
