  • arduino不能完全接受openmv发送的图像像素坐标数据。
    • 0_1633400253158_af3145da-6e3b-4651-b6ee-96f7e9dcf10d-1633400234(1).png openmv代码
      Blob Detection and uart transport
      yellow_threshold = (65, 100, -10, 6, 24, 51)
      uart = UART(3, 19200)
      if blob.pixels() > max_size:
      max_size = blob.pixels()
          max_blob=find_max(blobs)
          print('sum :', len(blobs))
          output_str="[%d,%d]" % (max_blob.cx(),max_blob.cy()) #方式1
          print('you send:',output_str)
          uart.write(output_str+'\r\n')
          print('not found!')
      Arduino代码
      void setup() {
      // put your setup code here, to run once:
      Serial.begin(19200);
      void loop() {
      // put your main code here, to run repeatedly:
      if (Serial.available()) {
      // Read the most recent byte
      byte byteRead = Serial.read();
      // ECHO the value that was read
      Serial.write(byteRead);
    • 代码都是官网上的,没改过。
