求教,如何重复调用程序
import sensor, image, time,pyb,lcd led_R = pyb.LED(1) led_G = pyb.LED(2) led_B = pyb.LED(3) led_R.off() led_G.off() led_B.off() lcd.init() from pyb import Pin pin4 = Pin('P4', Pin.IN, Pin.PULL_DOWN) pin5 = Pin('P5', Pin.OUT, Pin.PULL_NONE) pin6 = Pin('P6', Pin.OUT, Pin.PULL_NONE) pin9 = Pin('P9', Pin.OUT, Pin.PULL_NONE) roi01 = (116,69,180,231) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.VGA) sensor.set_windowing((0,0,500,400)) sensor.skip_frames(time = 1000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) while(True): img=sensor.snapshot() value4=pin4.value() if value4==1: import check else: img.draw_string(116,130," NO",color=(0,0,0),scale=2,mono_space=False) img.draw_string(116,150," NU",color=(0,0,0),scale=2,mono_space=False) img.draw_string(116,170," SKID",color=(0,0,0),scale=2,mono_space=False) lcd.display(img,roi=roi01) print('no skid') pin5.value(0) pin9.value(0) pin6.value(0) led_R.off() led_G.off() led_B.off()
第一次import check是OK的
循环到第二次再次调用的时候,check.py是一个运行完成的程序,无法执行检测操作。
求教,如何让check.py程序循环执行,使上边的程序可以重复调用。我想达到的目的是pin4给信号后进行检测,检测NG后再次进行检测,循环三次完成后判断OK 还是 NG。 如果check程序增加While循环的话就会一直进行检测,我只需要重复3次就好。
以下为check.py程序:import sensor, image, time,pyb,lcd thresholds = [(16, 38, -12, 15, -20, 12),(14, 49, -6, 13, -17, 19)] led_R = pyb.LED(1) led_G = pyb.LED(2) led_B = pyb.LED(3) led_R.off() led_G.off() led_B.off() lcd.init() from pyb import Pin pin4 = Pin('P4', Pin.IN, Pin.PULL_DOWN) pin5 = Pin('P5', Pin.OUT, Pin.PULL_NONE) pin6 = Pin('P6', Pin.OUT, Pin.PULL_NONE) pin9 = Pin('P9', Pin.OUT, Pin.PULL_NONE) Count_I = 0 Count_ok = 0 Count_ng = 0 Count_num = 0 roi01 = (116,69,180,231) for i in range(3): sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.VGA) sensor.set_windowing((0,0,500,400)) sensor.skip_frames(time = 1000) sensor.set_auto_gain(False) sensor.set_auto_whitebal(False) img=sensor.snapshot() lcd.display(img,roi=roi01) pin6.value(1) Count_num += 1 Count_I += 1 i += 1 if Count_ok >= 9: break for i in range(15): i += 1 img=sensor.snapshot() lcd.display(img,roi=roi01) for blob in img.find_blobs(thresholds,roi=(165,175,175,60),pixels_threshold=50,area_threshold=100, merge=True,margin=500): if blob.area()>5500 and blob.area()<11001: img.draw_rectangle(blob.rect(),color=(255,0,0)) img.draw_cross(blob.cx(),blob.cy()) img.draw_string(116,145,"OK",color=(255,255,255),scale=3,mono_space=False) lcd.display(img,roi=roi01) area=blob.area() print('OK') print(area) Count_ok += 1 else: img.draw_rectangle(blob.rect(),color=(255,0,0)) img.draw_cross(blob.cx(),blob.cy()) img.draw_string(116,145,"NG",color=(255,255,255),scale=3,mono_space=False) lcd.display(img,roi=roi01) area=blob.area() print('NG') print(area) Count_ng += 1 if Count_ok > 8: led_G.on() print('total OK') pin6.value(0) pin5.value(1) img.draw_string(116,145," T OK",color=(0,0,255),scale=4,mono_space=False) lcd.display(img,roi=roi01) else: led_R.on() print('total ng') pin6.value(0) pin9.value(1) img.draw_string(116,145," T NG",color=(0,0,255),scale=4,mono_space=False) lcd.display(img,roi=roi01)
或者如何import完成后取消import
试过del了,但是会报Key Error
能否reload啊!!!??!!
所有的py文件叫做模块,调用的是函数,而不是模块。
你应该在check.py里定义函数,然后在main.py里调用函数。
感谢!!问题已解决!
