星瞳实验室APP,快速收到回复
  • 接收Multicast数据报错
    • 想使用组播的方式实现设备自动发现,在Python上经测试没有问题,可以正常接收,代码如下:
      import socket
      import struct
      import sys
      multicast_group = '224.0.0.6'
      server_address = ('', 23333)
      # Create the socket
      sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
      # Bind to the server address
      sock.bind(server_address)
      # Tell the operating system to add the socket to the multicast group
      # on all interfaces.
      group = socket.inet_aton(multicast_group)
      mreq = struct.pack('4sL', group, socket.INADDR_ANY)
      sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, mreq)
      # Receive/respond loop
          print >>sys.stderr, '\nwaiting to receive message'
          data, address = sock.recvfrom(1024)
          print >>sys.stderr, 'received %s bytes from %s' % (len(data), address)
          print >>sys.stderr, data
          print >>sys.stderr, 'sending acknowledgement to', address
          sock.sendto('ack', address)
      将代码改为MircoPython后,发现以下属性未定义
      socket.INADDR_ANY
      socket.IPPROTO_IP
      就自己找到了Python中定义的对应值填入MircoPython中,代码如下:
      sock = usocket.socket(usocket.AF_INET, usocket.SOCK_DGRAM)
      sock.bind(usocket.getaddrinfo('0.0.0.0', 23333)[0][-1])
      group = inet_aton('224.0.0.6')
      mreq = ustruct.pack('4sL', group, 0)
      sock.setsockopt(0, 12, mreq)
          print('waiting to receive message')
          print('received %s bytes from %s' % (len(data), address))
      然后在OpenMV中运行就报如下错误:
        File "<stdin>", line 39, in <module>
      TypeError: object with buffer protocol required
      请问这个是什么情况?是因为MircoPython不支持Multicast吗?
    • 忘记说了MircoPython中socket.inet_aton()方法也没有,但是自己实现了一个,方法代码如下:
      def inet_aton(ipv4):
          ips = ipv4.split('.')
          return int(ips[0]) * 2 ** 24 + int(ips[1]) * 2 ** 16 + int(ips[2]) * 2 ** 8 + int(ips[3])
    • 我猜不支持,这个我也不懂。
      http://forums.openmv.io/
      建议你去这里问一下。
