  • 如何将识别Apriltag的数字通过串口传输出去?也就是怎么将以下两个例程整合呢?并且需要连线的方式可以讲一下吗?
    • 第一个例程:
      # UART Control
      # This example shows how to use the serial port on your OpenMV Cam. Attach pin
      # P4 to the serial input of a serial LCD screen to see "Hello World!" printed
      # on the serial LCD display.
      # Always pass UART 3 for the UART number for your OpenMV Cam.
      # The second argument is the UART baud rate. For a more advanced UART control
      # example see the BLE-Shield driver.
      uart = UART(3, 19200)
          uart.write("Hello World!\r")
          time.sleep_ms(1000)
      第二个例程:
      # AprilTags Example
      sensor.skip_frames(30)
          for tag in img.find_apriltags(): # defaults to TAG36H11 without "families".
              print(tag.id())
    • 具体的代码需要你自己写。
      伪代码:
      导入所有的库
      初始化
          采集
              uart.write(str(tag.id()))
