  • 我更改了色块阈值 但是报错语法错误 不清楚为什么?
    • GRAYSCALE_THRESHOL = [(0, 50)] 改为了GRAYSCALE_THRESHOLD = [(190,255)]
      以下为修改后的
      # Black Grayscale Line Following Example
      # Making a line following robot requires a lot of effort. This example script
      # shows how to do the machine vision part of the line following robot. You
      # can use the output from this script to drive a differential drive robot to
      # follow a line. This script just generates a single turn value that tells
      # your robot to go left or right.
      # For this script to work properly you should point the camera at a line at a
      # 45 or so degree angle. Please make sure that only the line is within the
      # camera's field of view.
      import sensor, image, time, math#调用声明
      # Tracks a black line. Use [(128, 255)] for a tracking a white line.
      #GRAYSCALE_THRESHOL = [(0, 50)]
      #设置阈值,如果是黑线,GRAYSCALE_THRESHOLD = [(0, 64)];
      #如果是白线,GRAYSCALE_THRESHOLD = [(128,255)]
      # Each roi is (x, y, w, h). The line detection algorithm will try to find the
      # centroid of the largest blob in each roi. The x position of the centroids
      # will then be averaged with different weights where the most weight is assigned
      # to the roi near the bottom of the image and less to the next roi and so on.
      ROIS = [ # [ROI, weight]
              (0, 40, 80, 15, 0.7), # You'll need to tweak the weights for you app
              (0, 20, 80, 15, 0.3), # depending on how your robot is setup.
              (0, 00, 80, 15, 0.1)
      #roi代表三个取样区域,(x,y,w,h,weight),代表左上顶点(x,y)宽高分别为w和h的矩形,
      #weight为当前矩形的权值。注意本例程采用的QQVGA图像大小为160x120,roi即把图像横分成三个矩形。
      #三个矩形的阈值要根据实际情况进行调整,离机器人视野最近的矩形权值要最大,
      #如上图的最下方的矩形,即(0, 100, 160, 20, 0.7)
      # Compute the weight divisor (we're computing this so you don't have to make weights add to 1).
      weight_sum = 0 #权值和初始化
      for r in ROIS: weight_sum += r[4] # r[4] is the roi weight.
      #计算权值和。遍历上面的三个矩形,r[4]即每个矩形的权值。
      # Camera setup...
      sensor.set_pixformat(sensor.GRAYSCALE) # use grayscale.
      sensor.set_framesize(sensor.QQQVGA) # use QQVGA for speed.
      sensor.skip_frames(300) # Let new settings take affect.
      #不要太小 否则容易卡顿
      #关闭白平衡
          uart = UART(3,19200)
          uart.init(19200,bits=8,parity=None,stop=1)#init with given parameters
          centroid_sum = 0
          #利用颜色识别分别寻找三个矩形区域内的线段
          for r in ROIS:
              blobs = img.find_blobs(GRAYSCALE_THRESHOLD, roi=r[0:4], merge=False)
              # blobs = img.find_blobs(GRAYSCALE_THRESHOL, roi=r[0:4], merge=True)
              # r[0:4] is roi tuple.
              #找到视野中的线,merge=true,将找到的图像区域合并成一个
              # 在每一个ROI都会执行下述语句 所以总共4个ROI
              #目标区域找到直线
                  # Find the index of the blob with the most pixels.
                  most_pixels = 0
                  largest_blob = 0
                  for i in range(len(blobs)):
                  #目标区域找到的颜色块(线段块)可能不止一个,找到最大的一个,作为本区域内的目标直线
                      if blobs[i].pixels() > most_pixels:
                          most_pixels = blobs[i].pixels()
                          #merged_blobs[i][4]是这个颜色块的像素总数,如果此颜色块像素总数大于                     #most_pixels,则把本区域作为像素总数最大的颜色块。更新most_pixels和largest_blob
                          largest_blob = i
                  img.draw_rectangle(blobs[largest_blob].rect())
                  img.draw_rectangle((0,0,20, 20))
                  #将此区域的像素数最大的颜色块画矩形和十字形标记出来
                  img.draw_cross(blobs[largest_blob].cx(),
                                 blobs[largest_blob].cy())
                  centroid_sum += blobs[largest_blob].cx() * r[4] # r[4] is the roi weight.
                  #计算centroid_sum,centroid_sum等于每个区域的最大颜色块的中心点的x坐标值乘本区域的权值
                  print(centroid_sum)
          print("s")
          center_pos = (centroid_sum / weight_sum) # Determine center of line.
          #中间公式
          print(center_pos)
          # Convert the center_pos to a deflection angle. We're using a non-linear
          # operation so that the response gets stronger the farther off the line we
          # are. Non-linear operations are good to use on the output of algorithms
          # like this to cause a response "trigger".
          deflection_angle = 0
          #机器人应该转的角度
          # The 80 is from half the X res, the 60 is from half the Y res. The
          # equation below is just computing the angle of a triangle where the
          # opposite side of the triangle is the deviation of the center position
          # from the center and the adjacent side is half the Y res. This limits
          # the angle output to around -45 to 45. (It's not quite -45 and 45).
          deflection_angle = -math.atan((center_pos-80)/60)
          #角度计算.80 60 分别为图像宽和高的一半,图像大小为QQVGA 160x120.
          #注意计算得到的是弧度值
          print(deflection_angle)
          #1 Convert angle in radians to degrees.
          deflection_angle = math.degrees(deflection_angle)
          #将计算结果的弧度值转化为角度值
          A=deflection_angle
          print("Turn Angle: %d" % int (A))#输出时强制转换类型为int
          #print("Turn Angle: %d" % char (A))
          # Now you have an angle telling you how much to turn the robot by which
          # incorporates the part of the line nearest to the robot and parts of
          # the line farther away from the robot for a better prediction.
          print("Turn Angle: %f" % deflection_angle)
          #将结果打印在terminal中
          uart_buf = bytearray([int (A)])
          #uart_buf = bytearray([char (A)])
          #uart.write(uart_buf)#区别于uart.writechar是输出字符型,这个函数可以输出int型
          uart.writechar(0x41)#通信协议帧尾
          uart.writechar(0x42)
          time.sleep(1)#延时
          print("k")
    • 20行,中文逗号,改成英文逗号。
