  • 我这个代码一直报错,我在论坛里也搜不到为什么,本人小白,但这个有点急,希望有人能帮帮忙
    • # Line Drawing
      # This example shows off drawing lines on the OpenMV Cam.
      gainceiling=16
      constrast=0
      brightness=0
      saturation=0
      gainceiling_flag=1
      constrast_flag=1
      brightness_flag=1
      saturation_flag=1
      sensor.set_pixformat(sensor.RGB565) # or GRAYSCALE...
      sensor.set_framesize(sensor.QVGA) # or QQVGA...
      p0_in = Pin('P0', Pin.IN, Pin.PULL_UP)
      p1_in = Pin('P1', Pin.IN, Pin.PULL_UP)
      p2_in = Pin('P2', Pin.IN, Pin.PULL_UP)
      p3_in = Pin('P3', Pin.IN, Pin.PULL_UP)
      def Key_Scan():
          gainceiling_flag=p0_in.value() # get value, 0 or 1
          constrast_flag=p1_in.value() # get value, 0 or 1
          brightness_flag=p2_in.value() # get value, 0 or 1
          saturation_flag=p3_in.value() # get value, 0 or 1
          if(gainceiling_flag==0)
              time.sleep(0.02)  #延时20ms,防抖动
              if (gainceiling_flag==0):  #再次判断是否被按下
                  while (gainceiling_flag==0):  #等待松手
                      pass
                  gainceiling=gainceiling*2
                  if(gainceiling>128)
                      gainceiling=2
          if(constrast_flag==0)
              if (constrast_flag==0):  #再次判断是否被按下
                  while (constrast_flag==0):  #等待松手
                      pass
                  constrast=constrast+1
                  if(constrast>3)
                      constrast=-3
          if(brightness_flag==0)
              if (brightness_flag==0):  #再次判断是否被按下
                  while (brightness_flag==0):  #等待松手
                      pass
                  brightness=brightness+1
                  if(brightness>3)
                      brightness=-3
          if(saturation_flag==0)
              if (saturation_flag==0):  #再次判断是否被按下
                  while (saturation_flag==0):  #等待松手
                      pass
                  saturation=saturation+1
                  if(saturation>3)
                      saturation=-3
          sensor.set_gainceiling(gainceiling)
          sensor.set_contrast(constrast)
          sensor.set_brightness(brightness)
          sensor.set_saturation(saturation)
          Key_Scan()
      请在这里粘贴代码
    • 报错很明显啊,语法错误,30行后面都没加冒号
    • 还有在最开始加一句 from pyb import Pin
    • 还有应该把6行到13行的一堆变量放到25行的函数里面去,不然是全局变量。
    • 你这个第30行的按键判断不对,应该一直用p0_in.value(),否则是只读引脚一次,啥用没有。
      不只是第30行。
