  • 霍夫圆检测 五个球有两个检测不到
    • # Untitled - By: 81245 - 周三 7月 28 2021
      import sensor, image, time ,lcd
      sensor.set_auto_gain(False) # 颜色跟踪必须关闭自动增益
      sensor.set_auto_whitebal(False) # 颜色跟踪必须关闭白平衡
      lcd.init()
      红色 (20, 62, 31, 93, 18, 65)
      蓝色 (16, 63, -24, 51, -88, -19)
      绿色 (34, 72, -55, 28, 24, 59)
      黑色 (0, 42, -13, 7, -18, 6)
      白色 (56, 78, -9, -1, -20, -3)
      thresholds =[(20, 62, 31, 93, 18, 65),
                  (16, 63, -24, 51, -88, -19),
                  (34, 72, -55, 28, 24, 59),
                  (0, 42, -13, 7, -18, 6),
                  (56, 78, -9, -1, -20, -3)]
      def max_pixel(pixle_num):
          Max_pixel = 0
          Max_num= 0
          for i in range(5) :
              if Max_pixel < pixle_num[i]:
                  Max_pixel = pixle_num[i]
                  Max_num = i
          return Max_num
      yanse = ["红色","蓝色","绿色","黑色","白色"]
          img = sensor.snapshot().lens_corr(1.3)
          for c in img.find_circles(threshold = 3500, x_margin = 5, y_margin = 5, r_margin = 5,r_min = 5, r_max = 100, r_step = 2):
              pixel_num = [0,0,0,0,0]
              c_rectangle = (c.x()-c.r(),c.y()-c.r(),c.r()*2,c.r()*2)
              print(c_rectangle)
              img.draw_circle(c.x(), c.y(), c.r())
              #img.draw_rectangle(c_rectangle)
              print(c)
              for i in range(5):
                  for blob in img.find_blobs([thresholds[i]],roi=c_rectangle,merge = True):
                      pixel_num[i] = blob.pixels()
              this_c_color = max_pixel(pixel_num)
              print(yanse[this_c_color])
          lcd.display(img)
      我采用霍夫圆检测,为什么白色和绿色一直检测不到,是因为阴影吗
    • 是因为对比度不够,边缘不够明显。
    • find_circles里的阈值改一下。
    • @kidswong999 是再加还是减小
