  • 在OPENMV IDE 上运行示例程序报错 RuntimeError: Capture Failed: -4,如何解决?
    • # Hello World Example
          print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
    • sensor连接错误,联系售后维修。
