  • openmv3 cam7 gpio 控制高低电平 在循环中 硬件lcd 白屏 ,pc 显示图像。后死机
    • # Find Lines Example
      # This example shows off how to find lines in the image. For each line object
      # found in the image a line object is returned which includes the line's rotation.
      # Note: Line detection is done by using the Hough Transform:
      # http://en.wikipedia.org/wiki/Hough_transform
      # Please read about it above for more information on what `theta` and `rho` are.
      # find_lines() finds infinite length lines. Use find_line_segments() to find non-infinite lines.
      enable_lens_corr = False # turn on for straighter lines...
      import sensor, image, time,lcd,pyb
      p = pyb.Pin("P7", pyb.Pin.OUT_PP)
      sensor.set_framesize(sensor.QQVGA2)
      lcd.init()
      # All line objects have a `theta()` method to get their rotation angle in degrees.
      # You can filter lines based on their rotation angle.
      min_degree = 175
      max_degree = 185
      a=False
      b=False
      # All lines also have `x1()`, `y1()`, `x2()`, and `y2()` methods to get their end-points
      # and a `line()` method to get all the above as one 4 value tuple for `draw_line()`.
          lcd.display(sensor.snapshot()) # Take a picture and display the image.
          img = sensor.snapshot().gamma_corr(gamma = 0.5, contrast = 0.5, brightness = 0.3)
          if enable_lens_corr: img.lens_corr(1.8) # for 2.8mm lens...
          # `threshold` controls how many lines in the image are found. Only lines with
          # edge difference magnitude sums greater than `threshold` are detected...
          # More about `threshold` - each pixel in the image contributes a magnitude value
          # to a line. The sum of all contributions is the magintude for that line. Then
          # when lines are merged their magnitudes are added togheter. Note that `threshold`
          # filters out lines with low magnitudes before merging. To see the magnitude of
          # un-merged lines set `theta_margin` and `rho_margin` to 0...
          # `theta_margin` and `rho_margin` control merging similar lines. If two lines
          # theta and rho value differences are less than the margins then they are merged.
          for l in img.find_lines(threshold = 1000, theta_margin = 25, rho_margin = 25):
              if (min_degree <= l.theta()) and (l.theta() <= max_degree):
                 # img.draw_line(l.line(), color = (255, 0, 0))
                  if  l.x1()>55 and   l.x1()<75 :
                      a=True
                      #if ( abs (  l.x2()-l.x1() )<=5  ):
                      # print(l)
                      img.draw_string(70, 10, "ok-A", color = (255,255,255), scale = 2, mono_space = False,char_rotation = 0, char_hmirror = False, char_vflip = False,string_rotation = 0, string_hmirror = False, string_vflip = False)
                  # print(l)
              if (85 <= l.theta()) and (l.theta() <= 95):
                  if  l.y1()>60 and   l.y1()<90 :
                      b=True
                      img.draw_string(80, 60, "ok-B", color = (255,255,255), scale = 2, mono_space = False,char_rotation = 0, char_hmirror = False, char_vflip = False,string_rotation = 0, string_hmirror = False, string_vflip = False)
          img.draw_rectangle(0,60 , 128, 30, color = (255,255,255), thickness = 2, fill = False)
          img.draw_rectangle(55,0 , 20, 160, color = (255,255,255), thickness = 2, fill = False)
          if (a==True):               p.high()
          # or p.value(1) to make the pin high (3.3V)
          lcd.display(img)
          print("FPS %f" % clock.fps())
      # About negative rho values:
      # A [theta+0:-rho] tuple is the same as [theta+180:+rho].
    • LCD扩展板占用了P7引脚,所以不能同时使用。
      https://singtown.com/product/636/opeenmv-lcd-shield/
