怎么helloworld也不行呀?显示Sensor Timeout?
# Hello World Example # # Welcome to the OpenMV IDE! Click on the green run arrow button below to run the script! import sensor, image, time sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240) sensor.skip_frames(time = 2000) # Wait for settings take effect. clock = time.clock() # Create a clock object to track the FPS. while(True): clock.tick() # Update the FPS clock. img = sensor.snapshot() # Take a picture and return the image. print(clock.fps()) # Note: OpenMV Cam runs about half as fast when connected # to the IDE. The FPS should increase once disconnected.
RuntimeError:Sensor Timeout
之前还可以显示的,不知道是不是动了什么东西,就突然timeout了 而且连接的时候闪了3下红灯
看一下sensor模组是不是松了?
请问怎样检查sensor模组呢?
把sensor模组旁边的螺丝拧好。
