  • NameError: name 'format' isn't defined怎么解决啊?
    • import sensor, image, time,math,pyb
      from pyb import UART,LED
      red_threshold   = (16, 40, 21, 53, 47, 17)
      sensor.skip_frames(10)
      uart = UART(3,115200)
      K=2554
      def Tablefun(list):
          list_set = set(list)
          frequency_dict = {}
          for i in list_set:
              frequency_dict[i] = list.count(i)
          grade_mode = []
          for key, value in frequency_dict.items():
              if value == max(frequency_dict.values()):
                  grade_mode.append(key)
                  break
          return grade_mode
          Tab_distance=[]
          while(len(Tab_distance)<20):
              length=0
              if len(blobs) == 1:
                  b = blobs[0]
                  Lm = (b[2]+b[3])/2
                  length = K/Lm
                  Tab_distance.append(int(length))
          length = Tablefun(Tab_distance)
          # uart.writechar(int(length[0]))
          length = format(length[0],'0>3')+ "\r\n"
          uart.write(length)
          print(">>", length, "<<")
    • 这很明显啊,57行,format变量未定义啊。
    • @kidswong999 :你好,我在python编译器里都是直接使用format()函数的,请问在openmv里需要导入哪个库才能解决呢,之前在文档里找没找到🙂 🙂
    • '{:03d}'.format(length[0])+"\r\n"
